911 Turbo (930) Forum 1975-1989
80% track camber, caster and toe specs?
Old 05-21-2007 | 10:06 PM
cardsrule's Avatar
cardsrule
Default 80% track camber, caster and toe specs?
This week in class I am going to be aligning my 79 930. I just wanted to see what you guys are running for camber, caster (if any change from factory) and toe? My car is 80% track so not too worried about tire wear( i haven't checked but I bet that i am running 5 degrees neg now in the back) . The car has RSR coilovers and the factory bushings (which I am going to change, and yes I know when I do this it will have to be aligned again, i am doing this for practice ).
Thanks in advance,
Scott
Quick Reply: 80% track camber, caster and toe specs?
