No start, no spark.. electrical gurus help please
Well i'm sure I knocked stuff around in that area wrestling with the turbo, Intercooler, and removing a butchered aftermarket AC install but the plug was in just fine. Even after dismantling the plug on both sides nothing obvious poked out at me.. If it happens again i'll have a 15pin plug soldering party and replace the whole thing...
1 Post
I had an item almost as bad when without knowing it I bumped one of the relays on the left in the engine compartment. My car went from a 900 rpm sweetie to a must-pump-the-accelerator-just-to keep-it-running bitch! Everyone on the forum offered help and it turned out to be the forward most/inner most relay that was just barely out of contact on one pin that caused it all! I had bumped it doing something else. If you looked at it, it didn't look like it had been touched in years. I think that a large percentage of our problems with these cars are corroded pins on the relays and corroded sockets. And when we bump or move one just a little bit, the contact spot is no longer there and that one pin is no longer working.
I agree 911 rudy, I think are cars are getting to the age the grounds, harnesses, and contacts are getting so dirty and corroded everything is running marginally at best in these old cars. In the mind-set of "don't fix what isn't broken" we don't really ever do anything to maintain or service these issues. Then of course, it doesn't take much to bring the system down by one little change/glitch. If there's any problem I hate on a car its an electrical/electronic one. I can't see those little electrons flowing around and it bugs me trying to figure it all out.
It's a catch-22 (hmmm, that "22" number again). If you take the time to pull apart plugs that were last touched 25+ years ago in Germany to clean them it *may* be a good thing, or it may dislodge something three feet away in the harness and make you crazy. And I love pulling the tops off those relays when you try and pull them out, leaving the insides looking at you.. Wire brushing (gently by hand) the fuse blosk with all the fuses pulled and battery disconnected is another *good* thing to do, along with cleaning the battery terminals and clamps while in there..
Rennlist Lifetime Member
Almost always when I take that plug loose I will hit it with a wire brush and contact cleaner. Also watch for a crack plug. The plastic becomes very brittle with time and they love to crack causing a fitting to fall out of socket.
The round pole plugs in that connecter tend to spread over time as well. If you look at the female end you will see some with almost a 1/16 " gap. I try to gently close the gap with a pick. Also, on the male end you can gently push a pick into the tip and spread them as well. Careful not to spread too far though because you will bend one of the sides out too far and break it off or stick the pick through your finger which can cause you to talk to God in a way you will need to go to confession for!!LOL
