Clutch pedal – feels crunchy and sticks
I printed the picture and took it under the car with me. You'll have to snap the spring and arm in place once you have it lined up. That's one thing people forget.
Originally Posted by kens911
make sure you put the new helper spring in correctly, i have done it several times on my carrera but the last time on my turbo i had it backwards. it's one thing to look at the pics and go ok it goes this way but when you are on your back under the car it's easy to get mixed up.
Finally got the new clutch cable installed and am happy to report the crunchy clutch pedal is now fixed!
Guess it turned out to be the cable, when I removed the old cable and grabbed one end of it and
pulled, it reminded me of pulling a chain out of a barrel over the lip.
Still have to install the new D-Assist spring and properly adjust the clutch throw but that will come next weekend.
Cable was not hard to remove and install:
25 min to get the old cable out
35 min to install the new cable
2 1/5 hours to get the dam locking pin through the trunion at the pedal assembly
Buy a telescopic mirror, it is your best friend along with growing more joints in your fingers
Hope this helps any owners that have the same symptoms!
