Relay help
Relay help
I posted this on Pelican, no results.. thought some might be able to help here:
Does someone by chance have a picture of the back of the fuel pump relays in the front fuse box? Re; PO has the rear pump direct to the last fuse w/o a relay...I need to add a relay for the rear pump and looking at the factory schematics both front and rear relays hook together I would like to see how the proper hook-up between the two relays is done?
appreciate any help...
'76 w/'78 3.3
thanks
km
'76 w/'78 3.3
thanks
km
Now THAT's being responsive!! That's what makes it worth investing in a membership for this forum....great post Rocket! Ken, you should invest in a membership...it seems you got a much better response here....some really great guys. (and gals)
One post with a fast response and not even a thanks...
930 Rocket.. I apologize for not thanking you earlier As I really appreciate you taking the time to help.. I did start to reply and should have!.. but time kept taking me away, also I wanted to look more at what I have as far as the existing FP relay wiring and the ws manual schematic to try and understand the relation to your picture. .. I was able to take a look last night. I think I need to find the schematic for a 2.7.(I only have the turbo ones) as the existing relay has additional wires that don't relate to the manual but could be the connection you show? ( this is a no history turbo conversion project) The manual shows connections between the two relays and each relay #87 driving each pump?
Again I appologize, and am grateful for your help
km
km
No problem Ken. I was just messin with ya. LOL
For what's it's worth, i bypassed all the controlls in the rear and added a impact switch to the fuel pumps. They always turn on when I turn the ignition on and I don't have to worry about the relays, switchs, etc in the back working right to get the fuel pump relays working.
All you have to do is wire the impact switch to the ground wire(s) [the brown
wire] coming off the fuel pump relays and you are done.
