borla exhaust vs power haus exhaust
Rennlist Lifetime Member
H exhaust is B&B. Both are not going to add huge power unless you have the cxat removed. Personally Fabspeed is the choice I would recommend. I have sold and installed a lot of exhaust and these are a nice piece.
FWIW, I was on a tight budget and had an exhaust system built using a Magnaflow stainless steel muffler... not too loud and sounds great at WOT. Build quality of the Magnaflow is of a very high standard.
You can get them in a single or dual outlet configuration too.
yes was thinking about something like that later. if i'm not able to get the borla cheap enough, either that or get the mig welder out and make my own. was thinking of a cross between a fabspeed single and dual, 3 inch single in with 3 inch dual out. my welding id getting a lot better havent tried stainless steel yet but who knows? plenty of stainless steel scrap around here at work.
