front hub removal tool
1 Post
I can't believe it! There is a God. I had a slide hammer that I bought from Harbor Freight and I was prepared to modify it to remove my front wheel hubs, but when I looked at it I noticed that the threads on the stem looked real close to the threadfs in the hub. Guess what? They are the same. All I had to do to use the slide tool was cut a little point off of the end so that the threads could engage. The item # is 05469 and its made by Pittsburg. It was about $25 and comes with an assortment of dent removal tips which will still fit the tool.
1 Post
It is if you already own it! BTW it is $19.95 and how many other jobs does the porsche special tool do?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
