WUR removal - tips?
Former Vendor
WUR removal - tips?
About to remove the factory WUR and exchange it for the Leask adjustable WUR...
However, before I slither in there and unbolt that sucker and the attendant fittings, any tip for what to expect in the way of fuel, etc when removing/replacing?
Assuming you have a stock air box in there you will need to remove the intercooler and airbox in order to get at it. Other than that it is a simple R&R. Just be careful not to drop the little copper washers when you remove the nuts.
Originally Posted by 930LDR
..... Just be careful not to drop the little copper washers when you remove the nuts....
Originally Posted by RSRS
.... any tip for what to expect in the way of fuel, etc when removing/replacing?
I thought the hardest part was getting the aircleaner back on with all of the hoses attached properly, other than that it was a snap.
Ditto on the magnet, I have one or more in every tool box I own, they have saved me many times.
Originally Posted by srf506
Cory you are so right. trying to get that little hose on the fitting on the back of the air cleaner is a major pain in the a _ _!
