A crazy little thing called a WUR (warm up regulator)
Originally Posted by RSRS
Thanks!
That is exactly what I plan to do ;-)
In fact, I will probably buy a used LM-1/LM-3 setup from a Rennlist member. He set his up and is done with it.
IMO, periodic checks are all that are necessary once it is set.
I actually have a used LM-1 for sale. I have since bought the LC-1 so I can keep it in the car and log A/Fs all the time. PM me if interested.
One other thing, the clamp likes to fall off - the set screw on top of the clamp tends to come loose. What I do is use a large hose clamp to help secure the Innovate part to my Zork. Keeps it nice and tight.
1 Post
I tried to get some feedback on how you guys are running the wire from the sensor to the gage. I wired mine from the exhaust just after the turbo up through the heat sheild and then behind the center section tail light over to the left. I don't see a real neat way to run the probe wire to the cockpit and was wondering if any of you had already done it? Those big plugs on the end of the wires make holes take on a new meaning! I also would like to know how you guys are wiring the LM-1 gage so that it would be a permenate fixture. The manual says it should be on anytime the engine is running and just after start up. Can you run it to the accessory side of the ignition?
Rudy
Rudy
Waht happened to Brent or Brent 930 who had an adj WUR with a MSD rev control as a means to adjust it? I had a picture of it at one time. Was his design along the lines of what everyone is making now?
Former Vendor
He was the inspiration for Brian Leask's design - indeed Brian gives him credit for this.
This is the identical setup I have in hand - and will install soon.
Rudy
Rudy
As for a power source, it is true that the O2 sensor MUST have power whenever the engine is running. The sensor will burn up otherwise. I'm sure there are lot's of places for switched power inside the cockpit. Not sure about yours, but the cigarrette lighter in my car is switched...only on when the ignition is on.
Don't know what kind of connector you've got, but Radio Shack or most god hobbyist electronics stores sell tool kits that let you remove the pins from the connector housing and then reinsert them after you've fed the wiring through your hole. Might check around to see if this will work for you.
1 Post
Thanks guys. I'll try radio shack tomorrow. I could also use it on the H-4 headlights I bought. I have the original pigtails and a new relay harness and would like to not solder them together.
Originally Posted by Tom F
Would someone, please, explain the LM-1, LM-3, LC-1 thing? Thank you inadvance.
http://www.innovatemotorsports.com/products.php
The LM-1 is Innovate's basic hand held AFR meter. The others are like accessories and/or permanent gauges and such.
