Distributor and injector questions....
I really cleaned my my distributor inside and out (by flushing it) and then started to think about if there were any kind of bearings in there that might be greased. I took a look today at taking it apart and it was a no go. Is this the case or does some oil keep it lubed?
Where can I get my injectors checked and cleaned? What's the cost? If I need to replace them, where's the best place to get them? I saw that Vertex has them for $59.xx At this price, maybe it's worth it to just get new ones vs spening the money to have them checked out?
Jim
Jim
Originally Posted by A930Rocket
I really cleaned my my distributor inside and out (by flushing it) and then started to think about if there were any kind of bearings in there that might be greased. I took a look today at taking it aprt and it was a no go. Is this the case or does some oil keep it lubed?
Jim
Jim
I'm not sure about rebuilding the dizzy...I would imagine there are bearings and other internal parts (advance/retard mechanisms) that require lubrication. However, if the thing is now toast or will require a professional rebuild (add more to the budget...LOL) I still have the dizzy out of my '87 with a new cap, rotor, and Magnecor plug wires that I can loan you until you figure out what to do with your dizzy. Mine only had 42,000 on it when I pulled it for Electromotive.
As for the injectors, I had two bad ones that I replaced with new ones from Imagine Auto. Neil Harvey cleaned and tested my injectors. You might want to check this guy out:
http://www.specialtauto.com/porsche-parts/index.html
I had my CIS injectors matched at www.injector.com (Marren Fuel Injection) - he also has replacements that are matched.
I have a new-rebuilt dist from my 79 - PM me if you are interested.
I just took the injectors out, used carb cleaner with the little red hose attachment (which fits perfectly in the injector port) and sprayed until I got saw a fine even mist. If you want to get really scientific, get 6 test tubes and time your spray (5 sec) into each one and measure the levels.
BTW, no smoking during test.
That's my usual trick, but first I soaked them in injector cleaner (like usual). I used 2-3 cans of cleaner and couldn't get a good spray pattern. They seemed to be off and not spraying in a full circle. Plus, I thoght they should be atomizing the fuel better. Not that they were dribbling.
I'd figure you've already done the basic cleaning. Have you tried blowing compressed air from the outside to dislodge any contaiminates through the injector port? Yeah, the price of new ones doesn't justify getting them rebuilt.
I haven't used any air. Are you saying blow it from the pintle to the inlet?
Maybe I could squirt some cleaner in there and then hit it with air?
The distributor needs attention if you have any axial play, beyond a few thousandths of an inch. They have fiber washers that break. You can replace them with the same part from a 356 distributor rebuild kit from Stoddard, but it takes some patience. You can also get the pins to secure the drive gear from Stoddard. There are instructions on disassembling the SC distributor (very similar) in one of the service bulletins from the late 70s. My ignition timing was bouncing around 5 degrees (crankshaft) before I rebuilt mine.
If I recall correctly, one thing that marren will do is clean them / check flow / pattern, and if they're bad you can apply that cost toward new ones from them.
Tom,
I saw a rebuild on a distributor somewhere, but couldn't find it or remember if it was a 930 distributor. I'll check the play.
Also, I'll check with Stephen, as I thought he knew of a place that rebuilds them.
Jim
Jim
mine all sprayed fine I stuck the little red tube in the hole with a can of wd 40 after they had soaked a few days in carb cleaner. they all sprayed fine with a good spary pattern, you have to push pretty hard on the red tube though or you will end up wearing more than you get through the injector. I think I got as much on me as through the injectors on the first couple.
Former Vendor
http://www.witchhunter.com/
Look no further, this guy is great. Lives close by so I could personally see the whole operation - injector testing & repair is all he does.
A perfectionist - he found a bad #6 and possibly saved my butt from a lean related rebuild!
Take a look:
Take a look:
