Distributor and injector questions....
sorry but i don't recall price from marren. ...they were much higher than they originally thought. i'd just call. if i recall correctly they were the lowest cost from people i checked with.
I wouldn't bother sending CIS injectors to Marren - they're really set up for electronic injectors, and there's nothing they can do to "rebuild" a CIS unit. I feel that Bosch intended them to have a life of 100,000 km. After that, you're better off just putting in new ones. It is expensive, but you will feel a difference. I paid over $500 for a set from Porsche. Also, Porsche supply a different number (Bosch number) from what I could find on the aftermarket. That may, or may not, be significant.
P.S. I just had a set of Motronic injectors redone by Marren (for a friend's 3.2), and they did a great job - it made a significant difference in how the car drives.
Thanks Guys.
With mechancial injectors, you're right, what can be done but clean them? I've done that, but not to the extent the do. I did recheck them last night with air adn brake cleaner and I think they are OK after all.
I have always used RC Engineering with very good luck on all my cars - CanAm, 935, GT2, etc...
They clean, rebuild and blueprint. I believe I paid about $300 but that was for 12 injectors since my system uses 2 fuel injectors per cylinder...
So maybe $150 for 6...
They also provide a system generated flow sheet that shows all the characteristics before and after.
They also list the exact type, model, impedance, and flow rates which helps when you go to replace them...
Norm
Norm
Is that for electric or mechanical injectors, Norm? I just can't see what can be done to a mech injector other than cleaning (which does't hurt).
Norm
Norm
A930Rocket,
Electronic.
They change filter screens o-rings and I believe they machine the opening for the pintle to match the flow. But check with their site to be sure...
Norm
Electronic.
Norm
