How do I quieten my exhaust?
OK, the date is drawing nearer where I have to go and get my exhaust noise tested. I know it will fail
Is there anything I can do to quieten my existing exhaust system?
I have a dual tip Mille-Miglia muffler. Will blocking one outlet quieten the exhaust?
Originally Posted by ProtoCab
Then, would it be quieter if I fit a bigger, single outlet muffler?
I was thinking of fitting a 18" long Magnaflow single in/out anyway.
I also turned the tip down slightly to keep noise from blasting straight out. Magnaflow is good, but not sure if its good enough for your problem.
I have a friend who shoved stainless steel wool up the pipe just before he went. He actually stopped down the road a little and started stuffin'. Worked a treat. Was all blown out by the next day after a few good runs
Blocking one side will make it quieter, Have a dual tip as well and install a E-cutout on one side. E-cutout is a motorized valve. It's a little hard to see in this pic but it's on the ground next to the exhaust tip.
