...and for post number 930 - REBUILD P@RN
Well 1.65 is in the range. I thought I'd stay just under 1.7MM. When Neil Harvey did the original mock-up in his shop to measure the CR and stuff, he used 1.7MM. Once you've got assembly lube on the cam and the tolernaces are possibly changing, I thought it would be better to go slightly under what he used.
Thinking outside da' bun...
Awesome job. Looks liek a real beast. I havent gone over 3200rpms yet but I can already feel the difference in power after my rebuild. Mostly in fourth because its the only gear I can accellerate in and stay under the rpms while I break it in.
Anyway, the car feels like it almost has no turbo in it. Just very very linear power. The best way to describve it is it feels like a rubberband. When you hit the pedal you seem to be stretching power that doesnt recoil.
Originally Posted by IaAaron
IIRC the 996 based 4-door concept was called the 929 I may be wrong.? Glad to see the IA sticker on your tool box!!
