Tech Help - Installing Cyl Head Temp Sensor - special tool needed?
Location: Waiting for the pass behind you, or Sebastopol, CA
Can anyone share the secret to replacing this sensor, while keeping the wire intact? And keeping sanity?
I'm replacing a bad cylinder head temperature sensor, on an 87 930.
Does anyone use a special tool to screw in the sensor, while maintaining the attached wire?
There's not quite enough room for a box, open, or hydraulic line wrench. I used a deep 14mm socket to remove the old one, after cutting the old wire.
I'm about ready to make my own 14 mm deep socket - and grind out a slot up the side of the socket for the wire to stick out.
Any ideas?
Thanks!
Glenn
Any ideas?
Thanks!
Glenn
Glenn - I agree with Mike. You will end making a socket very similar to the ones you use to remove a Oxygen sensor.
Yasin
Yasin
Mike, Yasin, and Win -
Thanks for the help!
Mine isn't as pretty, but it did the trick.
Have a great weekend! This made mine.
Glenn
Glenn
