911 Turbo (930) Forum 1975-1989
CSI - How do you remove?
Old 03-29-2006 | 02:00 PM
RarlyL8's Avatar
RarlyL8
Default CSI - How do you remove?
OK, I give up.
How do you remove the cold start injector without first removing the Air Meter Assembly?
I've cut down a couple of 5mm allen wrenches and lack maybe a half inch of travel to be able to loosten the top injector bolt.
Old 03-29-2006 | 03:20 PM
Chet 930's Avatar
Chet 930
I just changed a cold start injector a week ago. I removed the air meter assembly. Its not that hard to do and it didnt take long either. Made the cold start valve R/R much easier. There are only 3 nuts holding the the meter assembly in place. You'll be there a lot longer trying to change the CSI with the air meter in place.
Old 03-29-2006 | 11:53 PM
RarlyL8's Avatar
RarlyL8
What about the fuel lines? Don't you have to crack and move all of them?
Old 03-30-2006 | 10:50 AM
Chet 930's Avatar
Chet 930
Yes, but it only took a few minutes to do and they come on and off pretty easy.
Old 03-30-2006 | 01:04 PM
nathanUK '81 930 G50's Avatar
I think you only need to undo them at the injectors. Shouldn't need to remove the pipes. I covered my injectors with elec. insulating tape when I did this.
Old 03-30-2006 | 05:40 PM
Chet 930's Avatar
Chet 930
You know what, I read this too fast earlier. You only have to remove the lines from the fuel head and move them back some. You dont have to completely remove them. Sorry I didnt clarify that earlier.
Quick Reply: CSI - How do you remove?
