Engine rebuild update
#110
Originally Posted by SoCal Mike
David, what kind of dyno are they tuning on?
#111
Rennlist Lifetime Member
The Dyno Jet has a brake. What they do is run it up and slam the dyno brake on and try to load the cells. It is not a wise idea since it will overheat the brake. The brake was only designed to slow the dyno, not load up.
#112
#113
We did some more tuning today. It's still at 0.7 bar but it made 416 rwhp and 357 ft-lb torque. I think 500+rwhp at 1 bar may be within reach . I'm going to take it home tomorrow and get some miles on it before I turn the boost up and put it back on the dyno.
#118
I guess I'll get back on my own thread for the update .
After changing the fuel system from running in series to running in parallel with fuel dampers on each rail and not getting any improvement in my lean side/rich side problem I looked at cam timing.
Sure enough, the right bank which showed to be too rich by the plugs, had the cam too retarded. I reset the cam timing and now both side's plugs show to be lean, but the lambda sensor shows rich. At least this problem is sorted out and I can take it back to the tuner for final tuning. It's a little too early to tell, but it seems peppier on bottom.
