The mystery of the bent connecting rod
I'd say knock (pre-detonation) but I'd suspect you would have some other tell tale signs of that in the combustion chamber. Maybe it occurred close enough to the center of the piston and the resulting force of the combustion going against the "rising" piston was enough to temporarily halt the piston causing the rod to bend/twist a bit.
Originally Posted by Chet 930
The cylinder could have filled with fuel at some point previuos and then unloaded. I have seen this a few times where someone doesnt know what thier doing with the CIS system and a cylinder or two will fill with fuel. Then they go and try to push start the car or get it to start somehow meanwhile the filled up cylinder trys to compress the fuel and who knows what gets damaged.
Originally Posted by m42racer
Sand man,
He's a Kiwi with a British accent, living in the US. Whats this world coming too!!
