930 Starter wires
Was wondering why both yellow wires could not tie to #50 on the starter seeing that the second yellow is for the cold start and needs only power when cranking over the engine.
Rennlist Lifetime Member
It was a safety deal. If the solenoid didn't work then the injector would not be active. Verses it getting power every time the key was hit and the starter didn't work for some reason and fuel continuously being shot into the intake.
You can wire it the other way. Just be mindful every time you hit the key fuel is injecting through the valve.
