it just wont run right.. help!
#31
i did a leak-down on it.. its was 3%... so if there was a leak i wouldn't be able to hear it.. the vavle adjustment was checked, valves are Spot on,
just randomly i aimed my digital laser temp gadget on the exhaust just below the flanges when i started the car...the thing only goes to 500*F
4 and 6 heat up slower then 5... #5 went off the scale. This mean I'm running lean in that cylinder(i can re-check everything i did on the fuel system..) or is it just because its in the middle and heats up faster...?
idk... random test... might just be pissing in the wind..
the next step is taking the whole injection system off and looking at the blocks... even though i already poured a ton of carb cleaner all over the area looking for leaks.. maybe i will re check the injectors for the 3rd time.. i dont know what to do at this point.
thanks for the help so far guys
-nick
-nick
