WTB 18mm front thru the body swaybar
The old swaybar in your garage when you added the smart racing 22mm adjustable bar to your 76 930. I would be happy to buy htis off you. This is the swaybar off the early 3 liter turbos pre 77 only.
Under suspension newer style bars are not needed...thank you.
Luke, just for measurement info, they should be 18mm on the front and back if you have a 3,0 turbo. The bar would have gone thru the body behind the gas tank. The 77 and later 3,3 have a 20mm bar with a different mounting set-up. I can not use the later. Let me know.
