Adjustable turbo boost knob
#63
No problems. But, as soon as it went up that high I backed off. I'm trying to figure out what was keeping the wastegate from opening. Seems to be two problems. The line coming from the manifold to the atmosphere side of the w/g and the boost ****. I disconnect both and I'm now at .8. I haven't gotten around to checking the lines to & from the ****.
'79 930/DP935
'79 930/DP935
#64
the PO of my car installed a manual boost controller, basically it allows you to "bleed" off boost.
I used to get 1bar now only mediocre .4-.6 bar Im trying dissect the lines seeing which ones go where.
