Andial Fuel Enrichment Adjustments
Curious to see if the Andial Fuel Enrichment Systems are adjustable and what kind of differences in settings there are. My 930 had one installed when I bought it and never really looked much into it. I will be installing Stephen's Fuel Head mod this weekend and am curious as to whether or not I need to turn the Andial unit down, off or leave it (testing will show that i guess).
Rennlist Lifetime Member
The only way to really know is to run a wideband on it or cut a plug under boost. In other words while under boost cut the igintoion and pull over, pull a plug and read it. Reading at idle really does not good because of the amount of fuel CIS dumps at idle.
I don't know if it is useful or nt at that point. After the head mod there is nothing else needed. If you are lean through the midrange I suspect that it would have merit. Normally these cars are very rich in the midrange so no need for the andial unit.
