911 Turbo (930) Forum 1975-1989
Fabspeed dual w/Tial 46mm WG?
Old 10-14-2005, 04:53 AM
Sameer
Sameer's Avatar
Default Fabspeed dual w/Tial 46mm WG?
Will be receiving my Fabspeed dual style exhaust anytime. Now the right side is straight from the muffler out but the left side is from the wastegate. Now I'm using the Tial 46mm wastegate so will any of you'l know if the left side tailpipe is a direct bolt on to the tial wg? The reason I ask is because the stock wg is bigger in size comparing to the Tial wg.
Old 10-14-2005, 08:12 AM
sand_man
sand_man's Avatar
I think it should be fine. I'm pretty sure the driver side Fabspeed exhaust tip/pipe (waste gate dump tube) has some adjustability in it to assist with installation and proper alignment. Be advised, though, that I don't own a Fabspeed, I'm basing my coments on what I've seen on their website and short videos.
Jeff
Old 10-14-2005, 09:47 AM
slownrusty
slownrusty's Avatar
The stock WG is physically larger and heavier than the 46mm TiAL but the exhaust port and the orientation and the way it sits on the header is identical, so on other words you will zero issues.
Yasin
Old 10-14-2005, 01:19 PM
Sameer
Sameer's Avatar
Sounds good, thanks guys.
Old 10-14-2005, 02:14 PM
Sameer
Sameer's Avatar
Yasin,
Any ideas if the flange where we bolt on the Fabspeed tailpipe to the Tial WG is the same size as stock?
Old 10-14-2005, 04:56 PM
FLYN930
FLYN930's Avatar
Sameer,
The Fabspeed dual outlet muffler, Tial wastegate and B&B headers are a good combination. I have been running this exact setup for nearly 2 years and I absolutely love it. Installation should be straightforward. Sand_man is correct in stating that the wastegate outlet pipe is adjustable so that you can align it to the cutouts in your rear valence. The muffler exit on the right-hand side also has a slip fitting for this same purpose. The Tial wastegate is not an issue as it's ports are identical to the original in size and placement.
Cheers,
Brian
Old 10-15-2005, 01:32 AM
Sameer
Sameer's Avatar
Brian,
Thanks a million buddie.
Old 10-15-2005, 02:06 AM
Sameer
Sameer's Avatar
Brian,
is your oil scavange pump from B&B? Looks good.
Old 10-15-2005, 04:02 AM
FLYN930
FLYN930's Avatar
The turbo sump tank is actually a GHL unit. I bought DonE's used B&B headers after he got his Marco Manzie setup, and Stephen at Imagine Auto hooked me up with a GHL sump tank for a reasonable price. The GHL and B&B sump tanks are nearly identical from what I can tell.
Best regards,
Brian
Old 10-15-2005, 07:58 AM
Sameer
Sameer's Avatar
Okie dokie
Old 11-13-2005, 12:59 PM
125shifter
125shifter's Avatar
What's the best source for the Tial 46mm as far as price and availability?
Old 11-13-2005, 04:58 PM
FLYN930
FLYN930's Avatar
I got mine in a Rennlist group-buy from Imagine Auto about 2 years ago. Stephen had a great price on them. Give him a call and see what he can do.
Cheers,
Brian
Old 11-13-2005, 08:47 PM
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
David, I too would like a Tial.
I wonder if Stephen could do a group buy for us, I'll take one if he can.
Any chance stephen ?
Anyone else want a Tial Wastegate ?
Old 11-13-2005, 09:06 PM
PorschePhD
Rennlist Lifetime Member
PorschePhD's Avatar
Sure I would come up with something. I would have to look back but I think the deal was 7 poeple. I will need to see what we blew them out for. So lets get a count. The more we get the better deal I get, therfore you get.
Old 11-13-2005, 09:36 PM
sand_man
sand_man's Avatar
I'm in for a Tial...if the price is right! I'm not taking any "overboost" chances when I finally get my engine back together! I just want a .8 spring.
Quick Reply: Fabspeed dual w/Tial 46mm WG?
