A little help wth my 911 please
6th Gear
I just purchased my first 911 turbo two weeks ago. I have had 911 over the years just no turbo cars. He is the problem. It is an out of state car, so it has to pass Washington State emissions to be licensed. No problem the car ran great. Wrong, it failed the CO%. cruise limit of 1 and it was a 3.69 an idle limit of 1.2 and it was a 4.55. Long story longer, I take it to one of the two porsche mechanics in the area, he retards the timing, leans out the mixture and reconnects the O2 sensor. The car passes emissions with flying colors, but I lost lots of low end power! When I question him on the performance He says disconnect the O2 sensor. Everything else is set to spec. Finally heres the question. Can I adjust back the mixture,if so how, and get some of the power back? Or is the change in the timing the issue? The car was idling a little high before, now its about 850. any advice would be great!
Thanks,
Brooke
Thanks,
Brooke
Rennlist Lifetime Member
You can adjust the mixture up and you should. If you don't you will lean the car out and if that doesn't kill the rings the exhaust valves will burn. I have seen 30K mile cars running stock specs and the valves will burn to the point you can see day light around them.
Do a search on google for the Gunson gas tester. Buy one and do your own CO!
6th Gear
Thanks for the advise. I am looking into a Gunson gas tester. As for the car the timing seams to be the problem. I have vacuum leak in the distributor advance canister. And the car was running on the lean side.
Brooke
Brooke
