boost gauge not working
My boost gauge just stopped working today. I haven't driven the car for a couple weeks and it worked fine then.
What can I check to see if a wire came loose or a chipmunk knocked something off?
Where is the boost senor located? Behind the IC?
Thanks,
Thanks,
If it is pegged at full boost check the brown and white wire going to the red sender on the intercooler or the Pop Off valve depending on your setup. Ground the wire down. If the gauge reads normal at that point then the sender is bad.
