Garrettson V.2 Intercooler Install
This intercooler is just temporary until I go to full EFI...
Then the car will get the entire motor overhauled, custom full wing intercooler... the works.
The stock intercooler just plain sucks *** on these cars once you start running a k-27 and 1bar of boost. BTW, I managed to drive the car for about 10 minutes and the new intercooler moved my boost threshold to 4000RPM from 3700 but the engine feels about 20-30HP stronger. My seat of the pants evalutaion may be off. I may run the car by the dyno again this Thursday to see if it actually made a difference. I wouldn't mind checking my A/F ratio at the same time.
E-man930
E-man930
I have measured the pressure drop across the intercooler at the shop, it registered just a hair over 0.5psi at 0.8bar, on other words very minimal.
Emanual - Those power increases you feel on the seat of the pants is about spot on! And you are right....the stock intercooler plain sucks, major heat soak and a 30year old design that just does not cut it today.
Yasin
Yasin
David - I got it off some guy called "David" somewhere in TX!
Yasin
Yasin
The stock intercooler should work fine with a stock engine. It's when you start adding more boost and/or run at the track that you might have detonation problems from too hot an intake charge. A larger intercooler doesn't really add power but it allows you to increase boost.
930, areas, bar, bb, core, garretson, garrettson, installing, intercooler, intercooling, logo, mounting, plate, porsche, tail, turbo, whale
