Water Injection
Aquamist is by far the most trusted system .
Some of the Supra guys used Propane injection and I think it would be perfect for some of the CIS cars who want to run big power for drag racing but are limited by fuel. The propane not only cools the intake charge but also acts as a 2nd fuel system so you could run a much bigger turbo and bigger boost and use the propane to supplement the CIS. Just a thought, not sure if it could work for these cars. I am sure Stephen would know...
TRB0 GUY
I personally know the developer of Heibar. Aquamist IS the most trusted system, but that's only because they're the biggest name in a small field of companies venturing in water injection. However, the Heibar system blows Aquamist to shreds! It's fool proof, helps emissions, and gives you a large torque increase without the risk of puddling whatsoever.
If you want a decent system, get Aquamist. If you want the best, go with Heibar.
...and if anyone needs a cheap test pipe, let me know. I just gutted a 930 cat and I think it would like a new home
-Kevin-
-Kevin-
