How to remove steering?
I use a 1/2" ratchet with the key out of the ignition. The ignition lock will hold the steering wheel while you loosen it up. Do not pull the nut all the way off. Hold the steering wheel at 9 and 3 o'clock and wiggle it back and forth. It will come loose. Then remove the nut and wheel. Other wise you might pull on the steering wheel and have a mouth full of it. BTDT. LOL
1 Post
Sameer,
Are you talking about the nut in the seat or the nut under the horn button? Both are required to remove the wheel. Just pry up the horn button and you will see the big nut.
Rudy
Rudy
