loosing air thru the bead seal on Fuchs
I've got the standard '86 set-up for Fuchs... 7" front, 9" back. I'm running Bridgestone Potenzas 225-50-16s up front and this is the second time I've needed to have my tires re-seated. I'm loosing air from the inside bead. The rim is not dinged, nor bent, or rough/ corroded, etc. and it's not the same spot or even the same tire as last time.
is the size just too big? or, not a good match of brands? I realize the recommended size is 205, but it doesn't over-bulge. Bridgestone info says 7" is fine for this tire....
