Transmission code/best oil for limited slip
My transmission feels and sounds like a limited slip. On the bottom of the final drive housing, it is coded 930.33/12 77700441. I believe that 930.33 is the type, and that 77700441 is the year and serial no. (My car is a 77. Also, I am doing this part of the number from memory, so I may be off a digit.) Does the /12 signify a limited slip differential? If it is a limited slip, what is the best oil to quiet it in low speed, tight turns?
Thank you.
Thank you.
RL Technical Advisor
Tom:
The ONLY true way you'll know if you have an LSD is to raise the rear wheels off the ground and spin a tire with the tranny in neutral. If both rear wheels rotate the same direction, you have an LSD,....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Use Swepco # 201.
If your LSD is stacked at 80%, it can be noisy and you should have that redone to 40%.
Its all in how the plates are stacked.
Use Swepco # 201.
