911 Engine Number Help
Hi:
I would appreciate it if someone could help me determine what year engine I have in my car. It is not the same year as the chassis and I want to get the correct info on it. I found two numbers on the engine:
1) 63E06781
2) 930 101 103 6R
I also found the following numbers on the Transmission:
1) 930 301 311 ORMB
2) 930 301 101 1R
Any help that you can give me would be great!
Thanks!
1) 63E06781
2) 930 101 103 6R
1) 930 301 311 ORMB
2) 930 301 101 1R
Thanks!
The engine type # is in the same area as the engine serial # (63E06781). I can't remeber if it's on the vertical pillar of the fan base or on the horizontal area to the right. The engine type # will give you more info as far as what it is and the specs for the motor (found in the little spec books sold by many parts dealers).
Mike M.
Mike M.
Originally Posted by emilios
Accordong to PET
63E is Carrera 3,2 Model Year 1984
