911 Turbo (930) Forum 1975-1989
Help needed configuring PLX data logger
Old Oct 28, 2004 | 12:34 AM
dyerkes's Avatar
dyerkes
Default Help needed configuring PLX data logger
I am in the process of configuring a PLX M-500 for data logging and was wondering if anyone on the board has already done this. If so, I would appreciate knowing the specifics of where you "tapped" the sources for: boost, RPM and MPH. Can you splice into the wires on the back of the gauges to connect to the controller? Also, if you created a voltage mapping of all of the gauges, I would appreciate it if you could mail me your configuration (or send a print screen of the configuration).
Thanks in advance,
David
1986 911 Turbo
