worn Pop off (dump-) valve question
Does anyone have any experience with worn out pop off valve and the results that may produce? Would it be likely that it could wear out at all so that pressure leaks back on the turbo's suction side, and is this a common problem on the 930 with K Jetronic?
thanks for your help.
The gaskets at either end of the bore is to cushion the impact of the piston hitting home at either end, the clearance on the piston to bore is what seals the chamber. The gaskets get old, brittle and soften up with oil saturation and fall apart. If you idle the car and just tap the throttle and hear a clicking noise, then the gaskets are gone. Worst case, i worked on a 930 that has a boost leak, and the gaskets had been gone for so long, that the piston had hammered the rear cap plate of the bore so much that it was cracked and had a huge vaccuum leak/boost leak.
