Helping a friend sell 1987 930
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
I'm helping a friend sell a 1987 930. I'm going to put it in the Rennlist Classifieds but I thought I'd post it up here first and give someone a shot at it. The car is located in Dayton, Ohio.
Here are the details as they were given to me:
930 Turbo Porsche
Excellent condition. 1987 930/911 Turbo. Meticulously maintained. Black exterior – Tan interior. All amenities. After market intercooler. Tial waste gate with barspring. Custom stainless steel exhaust, newer clutch, 6-way sport seats, blaupunkt 10 disc cd., low miles, service records available. Must see! Sacrifice $30K.
I can email you info on service that has been done and the shops that have done the work.
Send me a PM for contact info or email me at 944pete@rennlist.net
This is a great car at a very fair price.
Pics to follow in the next couple posts.
930 Turbo Porsche
Thinking outside da' bun...
Is that a GHL exhaust.
BTW, thats not a hateful price all things considered -- at least in the Ohio area. Assuming the car is tight like a drum.
Here's what I was sent on service history:
Service record Recap:
Purchased the 930 Turbo from:
Foreign Exchange
5269 Cobblegate Dr.
Dayton, Ohio 45439
937.298.3456
Contact: Rick Reilich
Date purchased: July 26, 2000
VIN # WP0JB0933HS05XXXX
Service records in chronological order by service provider (hard copies available).
Foreign Exchange
5269 Cobblegate Dr.
Dayton, Ohio 45439
937.298.3456
October 22, 1998
R&R Engine & transmission assembly rebuild
Frozen 1st & 2nd gears –
Replaced 1st & 2nd gears, replaced all syncros & gear teeth, Replaced R&R clutch assembly
January 27, 1999
Alignment
Turn front rotors, repack wheel bearings, balance front tires
Feb 16, 1999
Replace steering wheel bushing
Straighten speedo bezel
July 1, 1999
Install Radar Detector
May 2, 2000:
Adjust left bank valves
Replace 1 oil line
Sublet work – valve job
Rebuild Engine
June 21, 2000
Replaced fuse on fog lights
Checked front brake pulsate-light machine on ft.
Repacked wheel bearings
Reset idle
AC charge
August 23, 2000: Replaced left window motor
August 24, 2000: Install S.O. Full line
Adjust Valves
Install front lic. Plate
August 31, 2000: Mount & balance one new tire
Specialty Motorwerkes, Inc.
5325 Springboro Pike
Dayton, Ohio 45439
937.293.1188
Contact: Tony
September 11, 2000:
Replace clutch cables
Replace S/R cables
Adjust/repair muffler/tail pipe
Replaced lamps inspection r/r
February 22, 2001:
Replaced clutch
July 6, 2001:
R&R both rear control arm assembly
P3 Automotive
445 Miamisburg-Centerville Road
Centerville, Ohio 45459
937.312.9950
Contact: Dan 937.312.2126
June 25, 2002:
Bleed brakes and charge AC system
Track inspection
Brake fluid r12
January 19, 2004:
Replaced damaged window holding rail
Repair headlight connectors both sides
Replaced hood struts
Replaced wastegate with Tial Sport 46mm 1 bar
February 13, 2004:
Replaced oil pressure switch
April 21, 2004:
Replace gear oil
Brake fluid flush
April 29, 2004:
Diagnose and repair boost gauge, flush brake fluid, adjust idle
The Garaj
4796 South Dixie Drive
Dayton, Ohio 45439
937.294.2400
Contact: Yuri
September 6, 2002
R&R Driver’s side Window motor
September 23, 2002
Diagnostic Running Condition
R&R temp. sensor
R&R Fuel, Smoke intake system for vacuum leaks
June 30, 2003
R&R Oxygen Sensor
Replaced distributor cap and rotor
R&R spark plug wires
R&R Ignition coil
Adjust timing
White Allen European Auto Group
648 N. Springboro Pike
Dayton, Ohio 45449
937.291.6000
August 14, 2003
Charged air conditioning system
Inspected vehicle to meet requirements for driving event.
Oil & filter change, adjusted tire pressure
Performed brake fluid service
Repaired oil leak
Foreign Exchange
5269 Cobblegate Dr.
Dayton, Ohio 45439
937.298.3456
Foreign Exchange
5269 Cobblegate Dr.
Dayton, Ohio 45439
937.298.3456
October 22, 1998
January 27, 1999
Alignment
Feb 16, 1999
July 1, 1999
May 2, 2000:
Replace 1 oil line
Rebuild Engine
June 21, 2000
Reset idle
AC charge
Adjust Valves
Dayton, Ohio 45439
937.293.1188
Contact: Tony
September 11, 2000:
Replace S/R cables
February 22, 2001:
Replaced clutch
July 6, 2001:
P3 Automotive
937.312.9950
June 25, 2002:
Track inspection
Brake fluid r12
January 19, 2004:
February 13, 2004:
April 21, 2004:
Replace gear oil
Brake fluid flush
April 29, 2004:
The Garaj
Dayton, Ohio 45439
937.294.2400
Contact: Yuri
September 6, 2002
September 23, 2002
R&R temp. sensor
June 30, 2003
R&R Oxygen Sensor
R&R Ignition coil
Adjust timing
Dayton, Ohio 45449
937.291.6000
August 14, 2003
Repaired oil leak
I know Rick whos the owner at Foreign X. He will know the car if you describe it. Or I can ask him about it as I have to take mine back into him in the next week or so anyway. Also notice the Garaj did some work on it.
