911 Turbo (930) Forum 1975-1989
CIS Fuel pressure tester connectors
Old 04-01-2022 | 04:26 PM
p930t's Avatar
p930t
5th Gear
Default CIS Fuel pressure tester connectors
I need to perform a fuel pressure test on my 1980 ROW 930 and I do have a pressure tester, but the connectors are not the right type. None of the adaptors I have fit.
The type of connector seems to be of a special type (see pictures) and I am strugling to find the correct ones to build a complete tester.
What is the name of these female and mals connectors?
Where can I get them?
Or any suggestions on a complete tester that have these / adapters included?
Old 04-02-2022 | 05:52 AM
fritz k.'s Avatar
fritz k.
Hi, most likely it is a metric M12x1.5 connection with a 60 degree sealing cone. To be sure, measure the diameter of the male thread on the fitting, which should be about 11.85 mm than.
You need a configuration similar to this:
The ball valve has M12x1.5 male on both sides, the hose has M12x1.5 female on both sides. the pressure gauge has 1/2" on the bottom and is attached to the M12x1.5 t-piece with a suitable adapter.
Fritz
Old 04-02-2022 | 11:14 AM
p930t's Avatar
p930t
5th Gear
Thanks Fritz.
I do have a similar setup as this, but missing the M12x1,5 60deg cone fittings. These are the ones that I vcannot find locally at my hose and fittings stores.
