Need Assistance w/ 930 dashboard knobs
Need Assistance w/ 930 dashboard *****
Hello 930 Enthusiasts, I hope all is well.
I have a Euro 82 930. Regarding my dashboard *****, only my heated rear defroster lights up when the main light **** is turned to the on position. It lights dim when in the off position and when pulled out, lights up more brightly (attaching pics).
I am wondering if all my ***** are suppose to be this way (main headlights, rear fog-light and cigarette lighter). I have unscrewed and switched the ***** around, but they still don't light up. I think it would be really cool at night if they all did operate like my rear defroster ****.
Thank you for your input.
930SN - I also have a 1982 ROW 930. My front, rear fogs, and cigarette lighter all function. Here is what happens on my dash:
Headlights on
Then headlights on and rear de-fogger on:
Headlights on, rear de-fogger on, front fog lights on
Cigarette lighter works but the light does not iluminate.
Front fogs
Rear fog
I hope this helps.
Headlights on
Front fogs
Rear fog
I hope this helps.
Hello TurboX2, Thank you- Very helpful.
As I see it, my fog light **** should be lighting up with the main lights on like yours, but it does not.
What's interesting is that when I unscrew my rear defroster **** and switch it out with fog light ****, neither light up with the main head light to the ON position. So I think both the wiring for the fog light **** hosing and maybe the bulb in the **** itself must be defective? I will probably have to order a new fog light **** with a working bulb and have the wiring fixed.
Two question- Does your actual front headlight **** by the ignition switch light up when it is in the ON position? And lastly, my cigarettes lighter works but again it does not light up. I know yours does not either, but should it?
