front mount oil cooler
just installed front mount oil cooler in a 934 front spoiler. I have a 3.3turbo cooler and fan in my fender. I was told to leave that in and used the front mount also. Does anyone know how you run the oil lines. do you go into the fender cooler first then to the front cooler and back to the motor or do you go into the front then into the fender cooler ? The new front cooler has an-12 fitting. does anyone know what ends i will need on the new lines and how long should they be.If someone could reccommed who to call for advise and to get the lines i need. Thanks John
You don't need both. I have only the front on a 930 and it runs cool all day long. It never sees 200 degrees. It always runs arround 180 while driving and 200 in traffic. Hey this is LA and its hot(not AZ hot). If your gonna use both run oil from the fender then to the front cooler. Call Stephen I sure he knows what fittings are needed.
Fender Cooler to front cooler- back to the line
My 934 Oil cooler
Finished Pic
I'd like to see some pics of your setup once you get it done.
Brian
My 934 Oil cooler
Finished Pic
Brian
