911 Turbo (930) Forum 1975-1989
Mixture Question
Old 03-02-2004 | 07:20 PM
BrianKeithSmith's Avatar
BrianKeithSmith
Show us a pic Brent.
Old 03-03-2004 | 01:05 AM
Brent 930's Avatar
Brent 930
This is the display unit in the center vent where I can see it while driving.
Old 03-03-2004 | 01:08 AM
Brent 930's Avatar
Brent 930
This is the brain that mesures real time from the wide band O2 sensor then feeds the display and converts the scaled voltage to an A/F ratio on the display.
Old 03-03-2004 | 01:12 AM
Brent 930's Avatar
Brent 930
This is the wide band sensor hooked up past the muffler can in my case since I didn't have room just past the turbo and to hook it up like I wanted. The position will vary depending on your exhaust setup and in my case I had to get a bung tig welded to make it happen. I found out the hard way you can't use the bung at the collector of your headers.
Old 03-03-2004 | 09:10 PM
A930Rocket's Avatar
A930Rocket
I kept looking at the MSD and wondering how that was the brain. DOH!
Now speaking of the MSD. I read awhile back you used it in conjuction with your WUR (?) to help with your A/F ratios. It seemed like it was a better mouse trap than the Rice unit.
Can you explain how it works again? Please!
TIA
Jim
Old 03-03-2004 | 11:12 PM
BrianKeithSmith
And I want to know where you got the gauge that you placed where the clock use to be.
It looks like a boost gauge and an Exhaust Gas Temp gauge? Is that right?
Brian
Old 03-04-2004 | 10:28 AM
Brent 930's Avatar
Brent 930
Jim,
I will PM you about this since it could take some time to fully explain why and how.
Brian,
I got the gauge from Westach.com, I didn't have much room for the gauges I wanted without junking up the inside of the car so I went with the combo type. It worked out really well and then I sold my VDO boost gauge for almost twice what this gauge costed. Yes, it's a vac./boost and EGT gauge but you need to use some thick door/window tape around it for a snug fit.
Old 03-04-2004 | 10:48 AM
BrianKeithSmith
Thanks man! Good information. I'll probably get one of those.
Old 03-04-2004 | 11:02 AM
Brent 930's Avatar
Brent 930
No problem.
One other thing, in comparison to the VDO boost gauge it reacts alot faster to boost pressure and you can see what vacuum your running (should be 9-11 in Hg. at idle after warm). This way if anything changes with the vacuum you know you have a problem.
Old 03-04-2004 | 02:02 PM
SteveMB's Avatar
SteveMB
Brent,
I'd like some info on this gauge as well.
Old 03-04-2004 | 03:33 PM
BrianKeithSmith
Based on the info Brent supplied, I found this on Westach's site:
3 inch gauges for Turbo Test
Looks like they are like $120 or so.
Old 03-04-2004 | 04:20 PM
Brent 930's Avatar
Brent 930
I bought mine for $80
Old 03-04-2004 | 04:25 PM
BrianKeithSmith
share more dude... Tell us how you got it so cheap.
Old 03-04-2004 | 04:41 PM
Brent 930's Avatar
Brent 930
I must be special)
Maybe the price went up, did you call them and ask? The model I got is the 3C86T1.
Old 03-04-2004 | 04:45 PM
BrianKeithSmith
Is the gauge any more or less reliable than the stock boost gauge.
Brian
Quick Reply: Mixture Question
