Can you use 965 pistons in a 930 3.3 engine withought any other mods? I see them advertised as fitting with only cooling tin modifications. If is doable, would it be advatageous? I want to go tomfully finned pistons, and while I was at it, might as well increase displacement to 3.4 but I di not want to alter the case.
98mm is slip-fit into the engine case with no mods.
Yes, you must always trim the lower cylinder air guide plates, or, replace with 3.2L Carrera air guides.
