Crank no start - 82 911sc ROW
I have an 82 911sc ROW that we pulled the motor out for service. The motor is now back in and we can't get it to start. Here are the issues I am having. First, it seems that we only have spark on Cylinder one. Secondly, it doesn't sound like the fuel pump is running while cranking unless I have unplugged the lift plate. The CDI box hums the entire time while we are cranking. So far I have found replaced a relay because the old one appeared to be arcing occasionally. Another strange thing is that it seems like when the pin for 86 is inserted, it cuts power to the fuel pump. If I angle the relay and don't touch 86 the fuel pump will prime.
Team Owner
Firstly make sure you don't have the csv and air plate connectors mixed up.
Make sure the firing order is correct as the rotor spins ccw on the sc
Make sure the rotor is rotating also
Also make sure the distributor isn't 180 degrees out of phase
What did you do while the motor was out ? Did you Remove the distributor ?
If spark is available on one cylinder, it should be available on all cylinders even if the distributor timing is not correct. The CDI box humming is a necessary but not completely sufficient evidence that it is working properly, but, again, it is probably not going to be selective about which cylinder receives a spark - if it sparks for one it should spark for all. A possible "divide and conquer" approach is to spray a small amount of starting fluid into the air intake. If the engine starts briefly, the problem is fuel delivery, such as the fuel pump relay; if it doesn't fire at all, begin diagnostics with spark delivery.
Team Owner
We have spark all the way around now. The distributor cap wasn't all the way snapped in. So we have spark now and the fuel pump runs ONLY when SIR connector is unplugged.
Team Owner
I never removed the ground strap as the transmission stayed in the car. Seems like between pulling the engine and bad engine mounts, the strap was torn like 70% of the way through. Put a new ground strap on and set the CIS system properly and it fired right up. I've put about 4k miles on it since including a trip to the dragon after some Bilstein club sports, torsion bars, and RE-11's!
Team Owner
