oil level ?
Wonder about what the oil level should read, put on 2.5K this year and noticed that oil level was staying low, just above red. Checked level and reading about 1/4 way up from bottom mark to top mark. I never had to add oil b4, but normal only put about 1-2K on per year. No oil leaks under car, should I add and how much? I am about to store until spring, and next oil change, current running 20w50.
Jerry
Jerry
Hi Jerry,
Check it with the car fully warmed up and level at idle. It should come up to about the half way point or a little more but always leave it down at least a 1/4 from the top. It's best to check it at the stick too at the same time if you can.
I just ad about a 1/3 quart at a time if your just topping up the oil.
PS- How're things in the Porsche world in Israel?
Thanks, Ed!
I guess the opposite of my original question would be: Is it ok to add oil when the engine is cold, say first thing in the morning?
Truth be told, I'm not much a part of the Porsche community in Israel. But from what i've seen and the guys i've met, they're a good bunch! We have a great indy shop too! And the roads, oh G-d, the roads are amazing!!
You can add cold, but you won't be able to verify that you got the level to where you want it, until you warm it up. If you check it warm, and decide it needs some-why not add it then?
The post brings up a kind of Catch 22 situation - how do you know if there is enough oil in it to safely start it and warm it up, if you can only check the level when it is warm, level and running? If the engine is severely low on oil, you run the risk of damaging it by starting it and running it....
RL Technical Advisor
Great thread and I'm glad it was resurrected. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
We see a fair number of cars with grossly over-filled oil tanks and I think its largely due to lack of understanding about these dry-sump systems. Further, people don't always read the owner's manual and learn how to correctly maintain these engines.
For the record,...the ONLY accurate way to check oil level is with the dipstick. The gauge only gives a general indication and only when hot & idling. The dipstick is the "gospel" and is the primary tool used to determine how much oil is in the system and whether to add any or not.
Now,..the dipstick is only accurate when the engine is at operating temperature (85 deg C or 185 deg F), and after the engine has been idling for a few minutes on level ground.
Never, ever add oil to a 911 engine thats cold or not running. Never add oil to the top mark on the dipstick; maintain hot oil levels in the middle; between the two lines.
Failure to follow these procedures results in issues ranging from a huge external mess, to ruined cats, heavy deposits inside the engine and sometimes, bent rods from hydraulically-locked motors. I've seen them all.
I sure hope this helps someone.
Team Owner
dont get too caught up .. there is about 7 litres sitting in the tank that doesnt even get used until the thermostat opens .. The reason you check it warm is because you are doing a dynamic check of the tank with the thermostat open and the oil pumping too it.
You would have to be down to about 5 or 6 litres or so i imagine before you had an issue.
For axample i only put about 8 in after a change , then start it warm it up and top up the other 2 or thre i need. Really NOt an issue.
yes you can put oil in cold no problem. Sometimes when i check the oil and it is about a quart low I kust make a note if I am not at home or cant be bothered to fill it. No problem puting a litre in Later or the next morning.
Dont overanalyze this.
BTW sometimes when warm i top up by looking at the guage and watch it .. but does as Ed says , use the dipstick till you are sure. I always fill to max .. just coz ...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
BTW check out my updated dip stick from Porsche .. looks like they were aware of Steves point and lowered the levels a little for full...
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The oil level dip stick and oil level gauge measure the same thing. The oil level gauge is for driver to monitor engine oil level while driving, and is very handy. The gauge is accurate and the stick confirms this.
Oil change routine is add nine quarts. Drive engine until temp needle at middle white line or 90º C. Leave engine running and add quart number ten while watching oil level gauge needle thru rear window. Continue adding oil as you watch oil level gauge needle reach three-quarter mark. Check oil stick to confirm. Normal to get ten quarts plus part of quart eleven for near full in 3.2 liter. Works good for me.
On my oil changes, I put in 9 qts of oil and let the engine come up to temperature. To ensure the thermostat in the right wheel well opens, I make sure the oil cooler hard lines are hot to the touch. That way I know the system is circulating the oil and makes the level easier to attain (halfway).
