87 door lock trouble
Hey Guys!
I have a 1987 911 with some door lock issues. The set screw on the rear of the key tumbler fell out. I pulled the door apart, put in a replacement screw, and put it all back together. But now, I cant lock the doors:
- When I hit the central locking system button, the locks pop back open.
- When I manually lock the doors from the inside, the Central Locking light goes from off, to on. I remember it being dimly lit when the doors were unlocked, and bright when engaged.
- When I try and lock from the driver side exterior, nothing happens.
- When I try and lock from the passenger exterior, the doors lock and then pop back up.
I found a post a while ago about this issue with details and pictures but I've been searching for an hour and cant find it. Any help will be much appreciated, thanks!
Hey Guys!
Likely its the microswitch. you need to get back in there and ensure it's oriented correctly, that indicates to the system if the doors are locked or unlocked.
http://forums.pelicanparts.com/porsc...se-advise.html
You need to make sure it's installed right and the tabs didn't break off.
