78sc Engine noise after brake line bleed/ loss brake fluid
A week ago my brake pedal had hardly any pressure. One look at resovoir told me why, no fluid. Added fluid and fine but still was loosing level of fluid. Took to local shop (Eurosport in Bensenville,IL) and they could not find any obvious leaks but noticed the top of resovoir with a finger tip depth of fluid around cap, decided it could be the cap gasket was very worn down and splashing was occurring. They bled my lines and installed new gasket in cap. When I left the shop I notticed a strange sound but thought it was another car. On way home from work I could tell it was my car. The noise is a rough sort of hoarse gravelly noise just up to around 2k rpm as I accelerate the noise goes away like a switch was thrown. Noise almost feels like a window is down and then raised. It's a rattle like sound coming from rear passenger side. Any ideas? The car was sold with documents and specifically said tensioners and head studs have been addressed though its obvious not with upgraded ones. I called previous owner who said head studs were replaced and tensioners swapped for new old stock. Car has 36k miles. I will go to the shop tomorrow. Worried.
Sher
Sher
UPDATE
So this morning I left my garage and could still hear that noise. It wasn't constantly there, but came on and off thought my commute. Since there is traffic both yesterday and today (rush hour) I wasn't able to really open her up. This morning though, traffic cleared and I got the speed up to about 80. After that the noise disappeared. I exited the freeway and continued to head to the repair shop, but could not get that noise to come on. A mechanic at Eurosport checked out the engine and went on a ride with me... nothing at all to hear. The car runs like it should and did. The thinking now is that something may have been lodged somewhere and cleared itself. Not sure what to make of it. I will obviously pay attention to it for a while and see if it comes back. Any thoughts?
Sher-
Sher-
when it comes back get a sound clip. I would be far more worried about the dropping brake fluid, did you remove the drivers carpet and check round your pedal cluster ? IF ITS WET YOUR MASTER IS TOAST .
Sher-
