911 Forum 1964-1989
Rotor Noise
Old Apr 18, 2017 | 02:17 PM
jamesrg's Avatar
jamesrg
Default Rotor Noise
Hey guys,
Air cooled newbie.
My car recently started making a noise that I could hear on slow speed from the front left tire.
I thought my front bearings where grinding, there is a little bit of play per my mechanic so I will get them replaced at the next visit.
However, after some research I was going to adjust them.
I took the wheel off and spun it. That is when I noticed the brake pad seems to be grinding on a certain part of the rotor.
Took a video of it. (I know need to clean them up), at the beginning of the video look at the rotor and you can see what appears to an imprint of the brake pad.
It gets more friction at this spot when turning the rotor and I believe this is what is causing my noise.
Here is the video, and I welcome your thoughts and opinions.
What is the cause and what should I do?
THANKS!
Old Apr 18, 2017 | 04:38 PM
theiceman's Avatar
theiceman
Team Owner
you definitely have run out , but I would check that heat shield on the inboard side, make sure it isn't rubbing against the rotor.
Old Apr 18, 2017 | 04:45 PM
jamesrg's Avatar
jamesrg
Thanks ICEMAN!
Old Apr 18, 2017 | 10:09 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Sometimes a small stone gets caught between the heat shield and the rotor, causing a grinding noise.
Old Apr 18, 2017 | 10:21 PM
r911's Avatar
r911
Anti-Cupholder League
measure the runout with a dial indicator
how old are the rubber hoses??
Old Apr 18, 2017 | 11:50 PM
rusnak's Avatar
rusnak
I haddah Google dat
From the video, it's hard to tell. Doesn't look that bad. But if your bearings are loose, then the rubbing is much worse because the hub will wobble. You can pull the pads and see if they are worn into a wedge shape. I'd check the bearing play with the car on the ground. Grab the tire and rock the car side to side.
Old Apr 19, 2017 | 09:41 AM
jamesrg's Avatar
jamesrg
I cleaned up the pads and rotors real well and adjusted the bearing nut. Seems to be better for now.
I will be purchasing a brake kit to replace everything and having my local mechanic do the bearings at the next visit.
Thanks all.
Old May 30, 2021 | 03:54 AM
der Mond's Avatar
der Mond
Default How's she running?
Did you get the rotor problem fixed? If you had the pads replaced, the piston has to be in the correct rotation position as it has raised and relieved sections to prevent squeal...
Anyway, just wondering if it is still killing bugs fast...
Old May 31, 2021 | 08:09 AM
Daytonacoupe66's Avatar
Daytonacoupe66
Also, ensure that the spacer ring and O ring are on the spindle. When I replaced front bearings and brakes mine were not there. I understand that I'm not the only one to have learned that an earlier wrench binned these essential parts.
Old May 31, 2021 | 10:57 AM
theiceman's Avatar
theiceman
Team Owner
that post was 4 years old, he likely has replaced the brakes again since then
