911 Forum 1964-1989
78 SC !
Old Mar 30, 2017 | 04:34 PM
TerryShugart's Avatar
TerryShugart
During the cookie cutter production they came in black, silver and gold. I don't know if the colors are year specific.
Terry
75 911S
Old Mar 30, 2017 | 05:00 PM
bv shady's Avatar
bv shady
Turn signal lenses are wrong for a US import car (amber instead of red). Radio is aftermarket, smog pump removed, front chin spoiler has been added.
Old Mar 30, 2017 | 06:23 PM
Mark Salvetti's Avatar
Mark Salvetti
"Upgraded chain tensioners" would suggest pressure-fed, but the oil line isn't there on the right side.
The top invoice seems to have "test and clean speedometer....(something)". Looks like that was 2016. Gotta wonder if the speedometer was working, and might cast some doubt on the mileage (although the car does look really clean). Too bad no photos of the underside.
Mark
Old Mar 30, 2017 | 07:45 PM
bv shady's Avatar
bv shady
I was thinking the same on that invoice regarding the speedometer.
Old Mar 31, 2017 | 02:16 PM
iFox's Avatar
iFox
WOW Great eyes!...I started another thread about it but yes on the tensioners. Reid Vann from REIDVANN inspected the car .. he said it was in great shape... he also wondered about the tensioners as there are no tell tale lines going in.. he wondered if they were replaced with the old style ones? Would that make any sense? What do you make of the parts you said were not there?
Sher-
Old Mar 31, 2017 | 02:20 PM
iFox's Avatar
iFox
Default underside
Mark
While I was at ReidVAnn it was shown to me and Reid said the underside was remarkable because of this gold/yellow like color and original coatings. He saw and showed me this on several surfaces and he said the car had no rust and saw hardly any wet environments. I can';t remember what he called it but it was something like cad (cadmium?) not sure.
Sher-
Old Mar 31, 2017 | 02:23 PM
iFox's Avatar
iFox
Why would the smog pump be removed? Also what about those turn signals? I have spoken to the previous owner and he was the one who had all the work done.. I have since put out a call to him to ask about those tensioners.... is it possible he would lie about both the tensioners and the head studs? Reid had no doubt that it was a very well kept car and that the millage seemed right.
Sher-
Old Mar 31, 2017 | 02:41 PM
bv shady's Avatar
bv shady
Many remove smog pump if they are in states which don't visibly inspect for passing emissions. No harm on doing so as long as it was done correctly and everything plugged accordingly. Lenses were most likely cracked and are NLA. Did PPI do a leak down compression test and what were the numbers? I think its odd that the car had 36K on the odometer but needed a glass out repaint and engine needed $10k work. Maybe I'm a little paranoid but you paid high water mark for that car. Best of luck.
My 78 SC........
Old Mar 31, 2017 | 02:48 PM
TerryShugart
You'd remove the smog pump to reduce the engine load from the pump. As to tensioner's. In 1980 there was a tensiioner upgrade that was not pressure fed. Along with the tensioner's the chain sprocket carriers where made wider and have two bronze bushings. These changes were made to relieve binding stress. These have been shown to be trouble free when compared to the earlier ones. You can add safeties such that if they do fail you won't eat the valves. Recommendation I've seen is to replace them as a preventative measure every 40k to 50K miles.
Terry
75 911S
Old Mar 31, 2017 | 02:59 PM
iFox's Avatar
iFox
I never said it was a glass out repaint. What suggests that is what happened? As far as the leak down compression test.... I don't think so but I will see. Also I paid $52K. Have you ever heard of Reid Vann?
Sher-
Sher-
My 78 SC........
Old Mar 31, 2017 | 03:11 PM
iFox's Avatar
iFox
I called and Reid did not do a compression test and said that the engine ran flawlessly. I don't know much about these cars (YET) but he seemed to be very very knowledgeable. At some point a little trust must be put forward. I am hoping for the best. As far as the price goes... I have been looking for a couple years and while I haven't seen and drivel a lot, I have seen and driven a few. I have seen similar with higher miles go for a little more than I paid. A quick search will turn up quite expensive example with much higher millage and obvious wear signs. Not for nothing but this car is exceptionally clean. While I take comfort in that, its more important to have good mechanicals. Since there was no rust and good paint and it runs and shifts so smooth... what should I now be worried about? Your car looks amazing BTW... lowering it really looks like the way to go... I also love the chrome/polished trim. Where would you go from here if you were me? I am wanting H4's but I need to know if Bosch and relays are the way to go and if so from where...also I am thinking of the porsche classic radio as I like the look and need the handsfree.
Sher-
Old Mar 31, 2017 | 03:40 PM
TerryShugart
H4 is a bulb type and Bosch is a manufacturer of a lot of things. The H4 has two elements in one bulb. The conversion I think you are talking about includes the bulb change and also the housing assembly that gives a flush look to the headlights. The bulbs can be had in different wattage's.. The most common for this conversion is 55/60 which draws current comparable with the original sealed beam lights shipped on US cars at the time. You can add relays that will route current from the battery directly to the lights and not run 5 to 6 amps through the dimmer and headlight switch. If you increase the wattage to say 80/100 you should add the relays.
Terry
75 911S
Old Mar 31, 2017 | 03:52 PM
bv shady's Avatar
bv shady
Sher,
you mentioned it was resprayed and expensive this is usually indicative of a windows out job. Sorry for the assumption. I am very peculiar when it comes to documentation of my vehicles and thorough PPI's when I purchase why I asked about the compression and leak down. To each his own, I wish you the best with your SC! PelicanParts 911 forum also has tons of information. Welcome to the club.
Old Mar 31, 2017 | 03:55 PM
iFox's Avatar
iFox
Thanks for that... yeah I am kinda late in the game on do diligence this time around and I hope it won't cost me dearly. I am loving the car, to be sure... but boy are there sorry stories out there.
Sher-
Old Mar 31, 2017 | 03:58 PM
iFox's Avatar
iFox
Terry
75 911S
Yeah I was meaning the conversion. I saw on eBay varying prices on eBay and was wondering of there was a conversion that was better than the rest? Would using the higher wattage bulbs and relays be the best way to go?
Also ... anyway to increase brightness to the instrument lights? Mine all work but they are somewhat dim even on max.
Sher-
