AFR bung location
The fine people at Innovate suggest installing the bung on the typically leaner bank of cylinders - best to err on the side of caution.
So, does my stock '74 with CIS have a typically lean side? Driver or Passenger (left or right) and how close to the muffler inlet?
Photos of an install with '74 type headers would be swell.
Thanks.
Thanks.
I haddah Google dat
Is this for a permanent installation, or for a tester?
I installed mine at a collection point where the two sides meet. You want to be upstream of any catalytic or smog equipment. I wonder if they are joking about a "leaner" side.
Permanent.
Car is a '74 so no catalytic or smog gear. My Exhaust is original 2in 1out so I have to choose either the right or left header. Their comment was generic - I suppose some cars can have different heat / intake / mixture readings from bank to bank. I've never heard of it before on a Porsche, but figured I'd ask, as there are many things in the world I don't know...
