911 Forum 1964-1989
help with front wing for backdate project
Old Aug 31, 2016 | 05:26 PM
gimkana's Avatar
gimkana
Default help with front wing for backdate project
Hi guys.
I am planning a backdate project and trying to sort all things before putting my hands on the job. The idea is a singer inspired 911.
I would like to keep the original parts as much as possible BUT i am not sure about the front wing if that is possible because of the turn signal casing and considering that the project will run on an 81 911. So here is the question (hope you understand what i mean): do you think it's possible to keep the original wing, find a way to fix under headlights the turn signal casing and weld the missing part between the end of turn signal and wheel arch.......did you get what i am trying to say?
I hope it's feasable because in this case i would be able to keep original wing and just install a long nose hood and the bumper singer style instead of having to get a fiberglass complete wing with the turn signal.
Thanx
Old Sep 1, 2016 | 08:26 AM
gimkana's Avatar
gimkana
Non one? Or maybe haven't been clear with my question?
Old Sep 1, 2016 | 10:25 AM
Amber Gramps's Avatar
Amber Gramps
Take a look at TRE. They have the hood you need and all the other bits. If you posted a picture of what exactly you are after we could point you in the right direction.
http://www.tremotorsports.com/page.cfm?Node=10276
Old Sep 1, 2016 | 12:58 PM
gimkana's Avatar
gimkana
Hey thanx for chiming in. Basically i would like to know if i can keep the original front fender and find a walkaround for the turn signal instead to buy and install this one:
Old Sep 1, 2016 | 01:30 PM
Amber Gramps
It seems to me that Dave at TRE has that little insert you are looking for. There are a couple cars below that have "R" corner markers on them:
http://911backdateproject.tumblr.com/page/5
Old Sep 1, 2016 | 01:33 PM
Amber Gramps
I used the "69R" TRE fiberglass inserts on the back on my car.
File Type: jpg
Old Sep 1, 2016 | 01:35 PM
froggert's Avatar
froggert
you mean something like this?
http://www.eb-motorsport.co.uk/productinfo.asp?id=360
Old Sep 1, 2016 | 01:42 PM
gimkana's Avatar
gimkana
Originally Posted by froggert
Exactly this on!! thanx mate
WOW amber, what a beauty!
Old Sep 1, 2016 | 01:57 PM
Amber Gramps
BOOM!!!
Old Sep 1, 2016 | 02:21 PM
gimkana's Avatar
gimkana
@ froggert: exactly!! thanx mate!
@ amber: WOW, what a beauty you got there!!
Now another question taking advantage of your knowledge: do you think that this part would fit without big issues considering that the original wing wil have a welded arch on it for the wide looks?
Old Sep 1, 2016 | 09:55 PM
Amber Gramps
My experience tells me that fiberglass parts need a lot of work. My ducktail was a bear to get even close to being presentible. The small light bits weren't so bad. The light insert may fit without any fuss or you may have to do all kinds of work, I am not sure what you've got so..... What are your thoughts? You've got your car right in front of you, no?
Old Sep 2, 2016 | 02:30 PM
gimkana's Avatar
gimkana
Yes, this is why i would avoid all the possible fiberglass and use it just when there are no viable alternatives. The tiurn signal casing is small enought to maybe be an easy fit.
No, haven't got the car yet. Sold my 993 a few years ago always having in mind this project and now i am ready to pull the trigger. However i am trying to know in advance in what waters i am getting in. Actually negotiating an 81 targa.
Old Sep 2, 2016 | 02:47 PM
froggert's Avatar
froggert
No FHE with the turn signal piece for backdating, but I do have an SCRS bumper from EB Motorsports and it's quite nice. I just drilled mounting holes, got it painted and bolted it on.
Old Sep 5, 2016 | 09:45 AM
gimkana's Avatar
gimkana
Thanx mate. Looking now for all the kits out there.
Old Sep 6, 2016 | 08:44 AM
Uwon's Avatar
Uwon
Been there.
http://forums.pelicanparts.com/porsc...rrera-rst.html
TRE now has nice stuff.
Hope this helps.
Johan
