i had a FVD Brombacher cat bypass installed, no issues but did end up getting a new oxygen sensor, seemed that removing the cat revealed a bad O2 sensor or just random events. all is well and am greatly pleased with the bypass, nicer low end sound and improved throttle response (my opinion), car drive beautifully
grgallo, I put in a new sensor a few years back so hopefully won't have an issue. Pelican/Fabspeed do offer "O2 Spacers" to alleviate any error light but I'll wait and see. Should have the install done by the end of next week.
Too lazy and/or busy to do a comparison video. The sound difference is so subtle that I doubt very much it would be noticeable when recorded.
The new development is that water has started dripping from between the original muffler and the mounting bracket. water from an air cooled car.
I believe it is a muffler failure that was probably accelerated by the installation of the bypass pipe (more flow and a wetter stream). So now I need to put on a new muffler. The domino effect.
Are you saying that there is a leak between the bypass and the muffler?
Not with the car now otherwise I would include a pic. (one from internet shown here)
The leak is almost dead-center from the muffler where it rests against the pipe connecting the exhaust manifolds. I can hear a bit of a blow sound as well.
I have both the fabspeed bypass and supercup exhaust. On my youtube link in the signature there are some vids of different configurations, however the sound capture leaves a little to be desired. As it sits now it's very deep and aggressive sounding at idle, but really has this trumpet like howl after 4,000 rpms. Probably won't be 'til next year before I do a proper recording due to the break-in of the rebuild.
I did the cat bypass myself on my 86' 3.2 911. Again not the same set up, but I can offer what I experienced with installation.
Installation was easy. I just cut my old bolts off with an air chisel and replaced them. I cut off the muffler straps with tin snips and had no other issues. If I had to guess it took me an hour at a leisurely pace.
I did a Bursch one in one out exhaust with the cat bypass. It is not loud at all. It made the whirl of the 3.2 have a little bit of more tone. It sounds really good when down shifting which is it's loudest point, however it is not loud. When accelerating it sounds good, but I have not noticed any noise that is unpleasant.
