Thinking about buying used CCW classics?
Think twice. I purchased a used set of classics last year and put about 3k miles on them, if that. On the way back from the PCA swap meet I developed a vibration around 80mph, figured I bent a wheel after a hard expansion joint impact north of Baltimore. Got home, pulled the wheels off to inspect them and found the wheels broken. Contacted CCW and sent them some pictures and they replied saying the wheels are a very old version of classics and several revisions behind the latest. Because of this, I'd need to update all four wheels. So what I've learned from this experience thus far, is to take caution when buying used sets of classics. Find out as much history about the wheels and the newer the better. Really displeased with the whole situation to be honest.
About a year ago, I got some new inner barrels from CCW. If just the centers have cracked, you should be able to buy just new centers. If you can get them, I'd certainly get all four.
I heard CCW had been sold. If you call, ask if John Purner is still there. He was the owner and very helpful.
Good luck.
Edit - my wheels were 8 years old and look very similar, although the bolts on yours look wrong.
Good luck.
It is a horrible situation. No cheap solution either. More frightening, is the simple fact that there had been several revisions to the design. I remember at one point they stopped selling Classics to 996/997 wide body applications. They were not considered safe, iirc. Sorry you are going through this.
Good luck.
Good luck.
I've been in talks with CCW and I can buy new centers finished in a similar gold color for $300 each plus shipping plus shipping the old centers back. I really feel like they could do better given the circumstances. Need to inspect the last two wheels to see if they're cracked as well. Been up at children's with my daughter the past two day so I haven't had a chance.
As for bolts, there are two versions of bolts you can get, normal arp 12pt bolts or the "race" version which I have that uses normal cad plated grade 8 3/8" hardware.
I've got the same wheels that are being discussed. I think your bolts are wrong. Your wheels may have been apart at some point.
Wheels do wear out. We deal with these issues all the time in vintage racing. Fuchs are becoming a real problem if you race or track your car with sticky tires.
The basic rule is to take all your wheels off and clean them when you get home from the track. Then spend some time looking for cracks.
Here's an article from Vintage Motorsport that deals with all of these wheel issues.
Richard Newton
Richard Newton
Richard Newton
Richard Newton
Fact of the matter is, they are used wheels. How they were used, and for how long, you will never know. This can happen with a BBS or any similar wheel (cast/forged/milti-peice). Wheels should be considered a consumable, just like brake pads, tires, wheel studs, etc.
I have a set of CCW race classics on my 964. Bought from previous owner of my car. Previous owner had them for a few years, in my possession for just 1 year. I recently cracked the right rear inner barrel. How? Don't know. Probably from commuting to/from the track on NY roads getting on/off this godforsaken Island. NBD. New barrel sent from CCW (they had the specs on file from previous owner). $220. I swapped the barrels in about an hour. Just have to be careful sealing the wheel when reassembled. CCW specs a specific silicone (GE5000) and cure time (24hours). CCW was very helpful and processed my order very quickly.
Sorry to hear about your situation, but don't be surprised when buying used "racing" crap with an unknown usage and lifespan.
I use dow 832 on all my rebuilds. I completely rebuilt these wheels when I got them to set them up for a narrow g body vs a 964 which they came off of.
Here are the bolts that John used on my wheels. They're ARP 12-point. They're generally stronger than a Grade 8 bolt. I think they run about 180,000 psi. The stainless ones you see here are rated at 170,000 psi. That's a lot stronger than a Grade 8.
Richard Newton
Historic Racing Images
