Technical data on oil cooler? Part# 96420722002
I am looking to install an OEM Porsche oil cooler on a project car, and I'm curious if anyone in the forum can tell me what the ID and pitch is on the cooler itself. They come supplies with a M30 1.5 adapter to the Porsche lines, and that part itself is also available separately. I'd like to screw in a more common adapter to go directly to AN fittings of my choice.... ie not use the 30mm adapter that comes with it.
https://www.ecstuning.com/ES1458230/...d8YaAirD8P8HAQ
ECS sells the cooler, here is the one I'm talking about. Any help is appreciated. Thanks in advance.
That looks like the 964 oil cooler. Are you working on a 911 or a 964?
The 911 oil cooler is very different:
http://www.elephantracing.com/oilhan...cooler-kit.htm
Love that site
http://www.elephantracing.com/oilhan...hoilcooler.htm
The same cooler is shown here, on that page too.
This has been described on many websites as being found on 911, 964 and 993 cars. I believe one site said 911 89-98 Carrera 4.
That is a photo of the oil cooler I want to use, I'm quite sure of that, regardless of which car it came from. What I really want to know, from the collective wisdom of the forum is what the actual ID and pitch is on the cooler....so I can use a different adapter, and order that and have it on the way as soon as possible.
Thanks in advance.
Alex.
Thanks in advance.
Alex.
Thanks in advance.
This is a 964/993 std rt side oil cooler
Alex.
Thanks in advance.
Alex.
This is a cooler for an '89 and earlier 911
The widemouth ie larger I/O ports is an Elephant proprietary feature
Answer is....
Well, RM European offered a recent 5% off on anything, so the price for this item dropped enough with free shipping to make it reasonable to order.
The factory fittings are in place with a crush washer and spec out to M22x1.5
This is a common size, and different places do stock a replacement fitting for M22x1.5 direct to AN so people can make their own light weight hoses elegantly attached to this cooler.
Pegasus sells a Setrab M22 x 1.5 to AN8, AN10 or AN12 male terminations.
The Setrab has an O-ring vs Crushwasher, but its more than a third of the price of a crush ring version from Pegasus at least.
Thanks for the different leads, but here's the answer so that anyone else trying to follow along might have it at hand.
