84 911 Maintenance
84 911 Maintenance
Hey guys, my 84 has been sitting in the garage for about 8 months. Time for a tune up. 43000 miles.
Anyone have a checklist in place on what I should do.
Probably can pieced it all together but was hoping someone has it documented so i don't have to think.
There is no set list of things to change to get you out on the road (as far as i know) because every vehicle is a little different depending on the conditions its been stored. Millage, weather, and many other factors come into play. The parts you throw at it are really up to you and how deep you want to get in doing this. technically you could probably just swap out the battery fire it up and drive it without doing a anything (obviously that's not recommended) but you could also go as far as draining the tank of the old gas, swapping out fuel lines that may have dried out and cracked, doing a full tune up of plugs, wires cap, and rotor. checking out brake lines that may have dried up. Over time oil that has been sitting can actually go bad so you might want to change that out...... Im not trying to scare you away or make you over think things just starting that its difficult to say what needs replacing after storage. Id swap the fuel filter, drive it straight to a gas station so you can try to dilute that old gas with fresh hi octane stuff and go from there. We probably have most parts that you are looking for to get it on the road again.
https://www.carpartsdiscount.com/porsche.html
I hope this was helpful. If you have any questions or if i can be of any further assistance please don't hesitate to ask.
